Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Power-Down Refinement: TM-14 Transmitter Module
Old 11-25-2008 | 10:58 AM
Default Power-Down Refinement: TM-14 Transmitter Module
Do you think the following update to the 14MZ will also be added to the 12Z, Sure would be a fine addition.
Thanks JK
Futaba has just released an update for the 14MZ and the FX 40. This
software update contains several very important updates for your
T14MZ transmitter.
Power-Down Refinement: TM-14 Transmitter Module-
When using the TM-14 FASST transmitter module in the power-down mode,
this update will provide you with an additional visual indicator to
ensure that you do not attempt to take-off while the RF output is in
the weakened (range check) state.
Previously the LED in the Futaba logo at the top of the transmitter
would remain solid green, thus indicating the typical RF output. The
LED now blinks, or flashes, when it is in the powered-down mode
providing you with another safety indicator to ensure that you enjoy
your modeling experience.
Old 11-25-2008 | 11:17 AM
Bax
Default RE: Power-Down Refinement: TM-14 Transmitter Module
We can only suggest this to Futaba.
Old 11-25-2008 | 11:24 AM
Bax:
Thank you for the prompt reply JK
