Setup changes between R6014fs and r607fs
FL
I'm in the process of converting my existing PCM/PPM planes to FASST. I'm using an R6014FS to set my small planes up for use with my new 12FG while I wait for a bunch of R607FS's and 608FS's, which, will eventually be used in them. I'm curious, if, due to the change in resolution between the R6014FS G3 2048 and the lower resolution of the other FASST receivers, I will have to adjust everything all over again (subtrims, endpoints, etc.) when I get the new 7 and 8 channel receivers?
