Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Programing questiona
Old 01-08-2009 | 03:52 PM
My Feedback: (16)
Default Programing questiona
Hi, I'm using a R6014 receiver via a PowerBox 40/16. My problems is when I plug two servos into one channel port on the PowerBox the servos work in reverse of each other. Is there a way to have two servos on the same channel so that they operate in the same direction for a given command? I also have two servos on each aileron each side one each for the upper and lower wing panels ( bi-plane)
Thanks for any help
Old 01-09-2009 | 10:42 AM
Bax
Default RE: Programing questiona
Since we're not at all familiar with the programming of your powerbox, we really can't answer your question. Does the powerbox have functions like the MSA-10 Servo synchronizer, where you can set center, endpoints, and direction of multiple servos on one receiver channer? You'll need to contact the maker to see if there's an answer to your question.
Old 01-09-2009 | 11:58 AM
My Feedback: (16)
Thanks for trying Bax. I think I got my simple answer form the boys at Duralite. It was as simple as assigning all left side servos like ailerons to one slot and then left side of one eleavtor servo to one slot, rudder servo to one, then start right side servos in the same manner. Then all other servos like throttel smoke ignition, kill etc. to the receiver itself.
I had been trying to put both elevator servos on the same slot , not on there own slot.................sometimes when your so tired you don't even think.
But again thanks
