Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
12fg programing question
Old 01-09-2009 | 04:15 AM
Default 12fg programing question
Hi.
I'm trying to set up a low throttle -> down elevator mix on my new 12 fg.
How do I shift the "center point" of the mix towards the low side of the throttle stick?.
I can use the throttle stick to turn the mix on and off at the desired point, but the mixing ratio is still with reference to mid stick.
And Ideas?
Anders
Old 01-09-2009 | 01:34 PM
Bax
Default RE: 12fg programing question
When you use a mix, it has an AFR graph. You just set the offset of the mix to adjust its center. This will usually require you to reset the endpoints as well.
Old 01-09-2009 | 04:20 PM
Bax.
I dont think I understand You completlely.
I have played around with the offset value in the prog. mix screen. All this seems to be doing is move the curve up or down the "elevator axis" i the graph.
Obviously i am mising something.
Anders
Old 01-09-2009 | 04:49 PM
Bax
If you set throttle as master and elevator as slave, then the position of the throttle stick will determine the elevator position. One way to do this is to use the "offset" That will move the curve up or down on the throttle axis. You can also use EXP2, which will make a single exponential curve of how the elevator mixes with throttle. You can also select "POINT", which will allow you to set the mix according to the number of points you set up on the screen. The left-to-right movement of the line is the throttle movement, and the up-and-down position of the curve or points indicate the elevator position.
Old 01-09-2009 | 05:41 PM
Thanks Bax.
I figured it out.
I set the exp2 curve. This way the value set for exp will efectively move the start point along the travel of the throttle stick.
Anders
