Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Reading actual trim values on 8UAFs
Old 03-07-2009, 03:01 PM
Default Reading actual trim values on 8UAFs
Hi
I have a 8UAFs TX and I am converting a number of model settings over to a 10C. The only thing that does not seem to be available is the actual trim settings stored for the four basic channels, Ail, Elev, Throttle and Rudder. One can read them from the LCD display and get close enough I believe.
One can read back the:
Trim Steps:
Subtrim settings:
After I am done moving the model profile/programming will adjust the "digital" trims on the front of the transmitter for the same "view" on the LCD screen which should be fine but was just wondering if the actual stored "trim" values could be read somehow.
ray
Old 03-09-2009, 12:07 PM
Bax
Default RE: Reading actual trim values on 8UAFs
The numbers are relative and really don't have "abolute" values. You should just measure the deflection of your control surface when in the neutral position and then adjust the linkage so that the trim on the new transmitter is as close to zero as possible.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
