Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
6014FS - installation
Old 06-02-2009 | 06:04 PM
teresos's Avatar
Default 6014FS - installation
Hi ....
I have the 6014FS Rx with the receiver antennas inside the fuselage being in close
to a big plate of pc board material (5,1"x 8,6") with the copper on it.
No power...just the material.
Do you think I will have any problems ?
Thanks in advance
Old 06-03-2009 | 09:36 AM
Bax
Default RE: 6014FS - installation
At least one of the receiver antennas need to "see" the transmitter at all times.  If the copper plate block them, then you have a setup for trouble.
Old 06-03-2009 | 01:03 PM
teresos's Avatar
Thanks , Bax....
If I remove the copper from the pcb with the Etching method , then the pcb material
will continue to affect my Rx , or it will be OK ??
Old 06-03-2009 | 03:21 PM
Bax
It's the metal that can cause the problem.  Anything that's electrically conductive.  Just the PC board material (resin or fiberglass) won't affect the signals.
Old 06-03-2009 | 03:47 PM
teresos's Avatar
...understood.
Thanks again ,Bax .
