one piece wire connecters
does any one know how to remove the one piece wire connecters containg 3 or more wires from futaba printed circut boards?not the two piece white connecters those are easy just not have found the trick for the one piece white connector.
Hi scalebldr,
You can use solder wick to remove the solder from the pc board where the pins are located. The connector should then just come off in one piece with wires intact. Also you may want to put a little electronic solder flux on each pin before using the solder wick to help the solder flow better. Remember to be careful not to get the pc board solder pads too hot as this could damage them.
I hope you find this information helpful. Should you have any further questions or concerns, please do not hesitate to contact us at 217-398-8970 for Support, 217-398-0007 for Service or via fax at 217-398-7721 or by email at [email protected].
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
Sincerely,
Krysta
