Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
8U Delta Programming
Old 07-29-2009 | 10:33 AM
Default 8U Delta Programming
I have been tryiing to program a Vortex with my Super 8and I think I finally got it all mixed right except for one detail. I have the rudders prgrammed on the gear switch to swing out as speed brakes but they still function as rudders when the stick is moved. Since I have the nose wheel slaved to rudders, I thought it should only operate the nose wheel when Switch E was Up (on). At least I think that is what I want for ground handling. Any hints would be appreciated.
Old 07-30-2009 | 10:40 AM
Default RE: 8U Delta Programming
I was thinking about putting the nose gear on channel 4 and moving the rudders to 6 & 7. That way, when the gear swith is up, using the P-mixes, the rudders would not be fuctional-they would only act as speed brakes, and the stick would only effect the nose steering. What do you think?
