Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
programme a 14 mz
Old 09-16-2009 | 01:59 AM
Default programme a 14 mz
Hi, i have a 14mz and dont be able to program a mine plane like i want. Can somebody help me?
The plane is a F16 jet.
this plane have 1 servo for wing, one for left, one for right,with one aileron at part.
have 2 servo for elevator that are separate, you know how that f 16 is.
I want that the elevator work as ailelevator, aileron and elevator.
And the ailerons want to work only as a flaps.
Now i tryed to make in a new model of radio program a plan with a wing with 2 servo as aileron and a tail as ailelevator.
But dont able to disable the work of aileron on the wing when i push the stick of aileron, beacause must work only like flaps.
Thank you
Old 09-17-2009 | 08:54 AM
Bax
Default RE: programme a 14 mz
You just set the two wing servos to "FLAP" in the Funtion section of the Linkage Menu and it will work the way you desire. Set VC1 to Aileron with Control set to J1 and Trim set to T1. That way, the aileron stick will still control the aileron function when you move it, but it won't use up any channels that are transmitted to the aircraft. The ailevator function will still work as you desire.
Old 09-17-2009 | 12:22 PM
Thank you Bill.
But what's VC1?
Old 09-18-2009 | 08:50 AM
Bax
It's on the second page of the Function menu, and is one of the virtual channels.
Old 09-19-2009 | 12:03 PM
Thank you.
all done.
