Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Older rcvr, module and servos with 9ch
Old 07-01-2003 | 02:59 AM
Default Older rcvr, module and servos with 9ch
I'm getting back into helis after a few years away from the hobby, and it's time for a new radio.
Can I use the FP-TP-FM transmitter module and a 128DF FM rcvr (from my old T7UHF) and my older S5101 servos with a 9CH? Or is this just old technology now, and it's time to buy all new stuff?
Also can I use my old rate gyro-a G154-with the 9C? Thanks, Mike
Old 07-01-2003 | 02:41 PM
Hi Mike,
The module, receiver, servos and Gyro, will all work with your 9C radio. You should have no problems at all as long as each of the items is in good working order.
I hope you find this information helpful. Should you have any further questions or concerns, please do not hesitate to contact us at 217-398-8970 for Support, 217-398-0007 for Service or via fax at 217-398-7721 or by email at [email protected].
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
Old 07-01-2003 | 02:59 PM
Thanks for the prompt reply. Can you tell me the difference between the 128DF and the newer 148DF, and are the older 5101 servos that much different from the newer 9001 servos. Thanks again, Mike
Old 07-01-2003 | 05:21 PM
Mike,
The S5101 servos have 55.6 oz per inch of torque at 4.8V, while the newer S9001 has 54 oz/in at 4.8V and 72 oz/in at 6V. The S9001 is slightly larger also.
The R128DF is the same size and weight as the R127DF, while the R148DF is the same size and weight as the R148DP, which makes it lighter weight and easier to install in a smaller plane.
Sincerely,
Krysta
Old 07-01-2003 | 05:29 PM
Thanks for the info
