7c won't turn on
My Feedback: (20)
OH
7c won't turn on
I've got a Futaba 7c transmitter that was plugged into an Accucycle trickle charger then wouldn't turn on after it was charged. It worked fine prior to that and I've used the charger since then without issues. I looked inside the case and couldn't find a fuse. Does anyone know if there's a fuse in there somewhere that could be checked? Any other ideas why this could have happened?
RE: 7c won't turn on
There is a protection diode, so the transmitter should not be harmed by trickly charging with the Accu cycle. It sounds as though the transmitter has other problems, but without seeing it, it would be hard to pinpoint anything. It would be best to send it into the service center to be checked.
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
[email protected]
Sincerely,
Krysta
[email protected]
