Using a 7C-2.4 TX with a simulator?
We've got a guy in the R/C Simulator forum trying to use his 7C-2.4 with a flight sim.
It appears that he needs to switch the TX to transmit in PPM mode. A couple of us looked through the online ptf files for the 7C to see how to set that PPM. It appears from the manual there is a way to set modulation, but not nearly enough information to figure it out.
Is there a way to set the sucker to PPM?
How?
How?
With the 7C 2.4 GHz FASST transmitter, you don't change modulation. The trainer output is already a PPM signal. You just plug in to a proper cord and go from there. If the individual is having difficulties with RealFlight, then they need to have their Interlink controller checked out. If they are working with some other simulator, then there may be problems with the connecting cord and how the software is interpreting the signal.
