twin thottle set up 3pjs, 3pks
FL
i cant seen to be able to slave ch. 3 to ch. 2-thottle on the 7:3 setting. they wont center on the same point. ch. 2 will do 7:3, but ch. 3-slave wont do 7:3.
they center the same on 5:5 and travel the same, is this the way it is? and why? the manual says that you can program ch 3 to slave to ch.1 or 2 and it should do what the master ch. does. ive tried on my 3pjs and my 3pks. thanks jose
FL
RE: twin thottle set up 3pjs, 3pks
bax,
first,thank you for your help!
when i set the offset to +/- 30 on the offset to match the netral point of ch 2 on 70/30, then remove some low side thow on ch3-slave, i then loose thow on the high side and it dose not move as much as ch 2. i think this is because i move the center point down 30 and now im 30 short on the high side. does that sound right? it works fine on 50/50. ive used futaba products for 25 plus years - 3pb, 3pjs, 3pks, 3egx- old school, and a 9c super for my planes, but i cant seem to get this[]
