Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
14MZ Function Changes
Old 03-18-2010 | 01:55 AM
Default 14MZ Function Changes
When I make channel changes in the function menu, I found that ATV values assigned to the channel do not follow the change.
For example, say you have channel one set as RUD with ATV values at 50% and channel two set as ELE with ATV values at 100%. If you go into the Function screen and swap the two channels, Rud would now have an ATV value of 100% and ELE would have an ATV value of 50%.
I don't know if other programming (i.e., dual rates, AFR etc.) follows the channel swaps or if they are like ATV.
Is there a way to change the channels in the Function screen and have ATVs follow the change?
My problem is that I had a plane completely programmed for 72mHz. When I changed to 2.4, the system asked if I wanted to remap for the FASST Multi. I answered yes but then noticed that if I want my primary channels on 1 - 6 (to use the HS mode) I had to change the channels in the function menu. That was easy enough but then I noticed that the ATV values did not follow the changes.
Old 03-23-2010 | 02:31 PM
Bax
Default RE: 14MZ Function Changes
That's normal. When you reassign the different channels, you are not actually moving them around, but re-doing them.
Old 04-03-2010 | 08:05 PM
Bax, I think he's asking how to LINK the ATV amount to the FUNCTION asignment. Or if its even possible to do so. I'm guessing that the Function asignment is separate from the ATV asignment and you have to adjust each one separate.
Old 04-05-2010 | 09:01 AM
Bax
The ATV is not "linked" to a function. ATV is set to a channel. AFR is linked to a function. If, for example, you want the elevator function to remain the same when you move it around, you set up RateA and RateB in the AFR section of the Model Menu.
Remember: ATV controls individual CHANNELS. AFR controls FUNCTIONS.
Old 04-05-2010 | 10:33 PM
Thank you for making that distinction
Old 04-10-2010 | 11:52 AM
My Feedback: (55)
That explanation really was helpful to me I keep stumbling over the AFR area and this was like the proverbial light bulb. Thanks.
Howard
