Need some help With 8FG and Saiplane programming.
My Feedback: (33)
FL
Hi,
I'm setting up a Glider with My 8FG and have a litlle problem when setting up Flaps.
I want to use SE switch as Launch,Cruise or Normal and Landing conditions , I have my Flaps programmed on the Throtle stick (J3) but I want them active only on Landing Mode.
On the Butterfly Menu I have the values on Launch and Normal set to o and just a value on Landing , but when I move the stick on the first two positions (Launch and Normal ) the flaps go up a bit and then to neutral again , I've tried all and can't find what's causing that??
Your help will be apprecciated ,
Tahnks,
epc.
Tahnks,
epc.
Without knowing the full programming of the different functions, we really can't tell you what might be happening. Because you'll need to tell us EVERY setting you are using, it would be best to send this in a letter. Most likely, you have an interaction with one of the other functions, and for us to duplicate the problem, we'd need ALL of your settings.
You could also pull the memory card and send the model memory to us via email.
