Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Elevon Settings 9CHP
Old 03-29-2010 | 08:01 PM
Default Elevon Settings 9CHP
Hello Krysta & BAX,
I have a wing set up with a 9CHP running on a Berg 4L receiver in ELEVON mode. Got the servos working correctly (elevator stick = elevator & aileron stick = aileron). The problem is they are reversed in normal as far as direction goes so I go into the menu and reverse the servo and now the elevator stick operates like the ailerons and vice versa. What gives?? Can you tell me what is going on and if there is any way to rectify this via mixes or etc. without going to a 5 channel receiver (trying to minimize weight)?
Thanks for your help.
Jim
Old 03-30-2010 | 08:38 AM
Bax
Default RE: Elevon Settings 9CHP
Swap the servos side-to-side. Just exchange their plugs in the receiver, and you'll find that the controls will operate the correct way.
