Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
12FG CHANNELS PROBLEM
Old 06-21-2010 | 02:19 PM
Default 12FG CHANNELS PROBLEM
Hi guys,
I'm facing a problem with my 12FG transmiter.
When i'm pushing the throttle stick to full power i have also an aileron movement...!!!This happens in all models.Also i can see this movement is servo monitor page in transmitter menu.I have no mixes on this plane.I don't know if i'm doing something wrong because i'm new in futaba transmitters.The software version on tx was the 1.3,i updated it to 1.6 and still have the same problem.
Why this happening?
Thanks in advance for any replies....!
Old 06-23-2010 | 01:50 PM
Bax
Default RE: 12FG CHANNELS PROBLEM
Is your transmitter set to Mode I, with aileron and throttle on the right-hand stick? Is it possible that you are inadvertently nudging the stick a little bit when you move it so that you get some aileron interaction?
