Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
9001 servo problem
Old 08-29-2010 | 07:04 PM
Default 9001 servo problem
I went to the flying field to fly my T.F.310, was doing my preflight check to make sure everything was hooked up right. When I let go of the aileron stick from full deflection, instead of the servo stopping quickly it would go back and forth a few times then stop. There are two servos on a Y harness but only the one would do this. So I went home thinking the servo pot was probably bad. But now it wont do it again. Ive never noticed anything like this before. Any thoughts?
Old 08-31-2010 | 03:01 PM
Bax
Default RE: 9001 servo problem
Usually, the difficulty you mention is the result of a bad or dirty connector, or possibly a bad solder joint where the lead is attached to the circuit board in the receiver.
