Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
12FG Condition Switch question
Old 09-08-2010 | 03:13 PM
Default 12FG Condition Switch question
I don't think this is possible - But just in case...
I have a function operated by a switch. For my application I have set a delay (AFR) so that when the switch is operated it takes about 2 seconds for the servo to get to the new position.
I would like to have a condition selected when the servo reaches the end of its travel.
Is this possible?
I know I can set the condition to be selected when the switch is operated - but, in this case, the condition is selected as soon as the switch is operated - not when the servo gets to the end of its travel.
Many Thanks,
=Adrian=
Old 09-09-2010 | 08:48 AM
Bax
Default RE: 12FG Condition Switch question
You can activate a condition with a stick position, but not a servo position. You can set a delay in the activation of a function when the condition changes, but it will be time-based and not position-based.
Old 10-06-2010 | 12:33 AM
You can't set a condition from a servo,
but you can set a delay so the condition is switched at or close to the time the servo ends its travel - within limits. The caveats are that the servo delay would have to be less than max to allow extra delay for switching the condition after time = servo delay + servo travel time; and that the result will always be approximate - that may be good enough or not.
Ken.
