12FG heli setup
Hi Bax.
Ok, here is how I set things up: Model Menu to Cond Select, here I have four conditions, normal, idleup 1, idleup2, idleup3, and hold. I am using normal, idleup1, and idleup2. I have set up rate 1 "AVCS" and rate 2 "norm" on switch GF. I am able to switch between these two rates on any of the above conditions. I have set my gyro to 70% on AVCS and 30% on NORM. All group settings were set to single. In the AVCS mode, I get a solid red light on my 520 gyro and in the NORM mode, I get a solid blue light. I have set up DR on switch SA at 75% and expo at -30% as per the gyro instructions. Does my above set up sound like what you were describing to me in your post above? Thanks, Mike |
RE: 12FG heli setup
We don't know what "switch GF" is, but if that switch toggles between conditions, you did what I described. However, if the gyro is doing what you want, then you did it "right". There is no "correct" way to set up the transmitter...if it's doing what you want, then it's "correct".
| All times are GMT -8. The time now is 08:06 PM. |
