RCU Forums
-   Futaba Radios Direct support forum (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/)
-   -   Setting Switch Endpoints (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/11638314-setting-switch-endpoints.html)
jbwilhelmi 04-19-2017 09:10 AM
Using switch SG on an MZ18, two position switch, for ignition. PowerBox spark switch wants 0% and 100% for on and off. Switch travels from -100 to +100. How do i adjust switch to go between 0 and 100?
Jack
Bax 04-20-2017 07:17 AM
You're getting different ways of saying the same thing confused. The powerbox wants a good range for the "one end, other end" movement. They're calling one end "0%" and the other end, "100%". For Futaba, "0%" is the center of the channel's movement, so one end is 100% in that direction and the other end is 100% in that direction.
Just use the 100% endpoints (or more) and you'll be OK.
