Receiver for 14mz transmitter
Need an additional receiver for my 14mz radio and the old ones I have are discontinued. What new receivers are compatable with the 14 mz transmitter?
Thanks John Kruger |
What Module are you using? 72MHz, 50MHz, or 2.4GHz?
2.4 GHz
Cool. Then any, and all, current 2.4 FASST receivers will work.
These include: R7104SB R617FS R7006SB R6208SB And few others that are better is using S.Bus. Frankly, the R617FS is my all time favorite RX. Robust, small, and well proven. Look here and focus in on receivers that do FASST. Your module will not work with a FASSTest only RX (telemetry). https://www.futabarc.com/receivers/air.html Here's the Futaba products page on TOwer: https://www.towerhobbies.com/cgi-bin/wti0002p?M=FUT Hope that helps. |
In addition, you need to remember when using the transmitter set to "7ch" mode, you only get failsafe on the throttle channel.
When using "Multi" mode, you get full failsafe options on all channels. modtron Oxford UK |
