R7008SB Channel Modes
Hi,
I want to use the above receiver in a small jet. The receiver Sbus output will be connected to a gyro for flight controls. I want to change the Channel Mode to mode D to use channels 9-15 for auxiliaries. Can you confirm that in this mode the Sbus stream will still output channel 1-8 data? Thanks, Malcolm |
In Mode D you will get channels 9 - 15 on servo ports 1 - 7 on the RX. S.Bus will connect to servo port #8.
S.Bus can connect to any channel, it depends on how you assign you servos. The modes allow you to get certain channels on the hard wired ports on the RX. |
Understood Bill,
just wanted to check that channels 1-8 will still be outputted from SBus port? Malcolm |
Originally Posted by Malcolm H
(Post 12657014)
Understood Bill,
Thanks Bill!
Mo |
