RCU Forums
-   Futaba Radios Direct support forum (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/)
-   -   Linking problem (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/11701614-linking-problem.html)
DLind43 08-24-2022 02:08 PM
Linking problem
2 Attachment(s)
Hope someone can help me with this. I have a Futaba 16IZ radio trying to link a Futaba R3106GF receiver where it repeatedly fails. I created a new model, switched to T-FHSS, then run the link procedure. although the light on the receiver goes from red to flashing red to solid green it never connects, and gives a failed message. I found that that receiver is compatible withFutaba radios that have the T-FHSS mode and i confirmed that the radio is in that mode. Any help would be appreciated.
FUTABA-RC 08-25-2022 06:53 AM
This is from the manual for the RX you are using
The R3106GF uses the T-FHSS Air (T6L Sport : Mono directional) system so if used
with another T-FHSS Air transmitter le.a. T10J. T6K). then the ID of the R3106GF
receiver will not be shown on the transmitter's display. A "NO LINK" indication or
the ID of a previously linked T-FHSS Air receiver will be shown. Nevertheless, if the
LED on the R3106GF displays a steady green light it is linked with a transmitter.
(Telemetry can not be used on the R3106GF.)
DLind43 08-25-2022 10:51 AM
Thanks for the info. I found that after eliminating the ESC and attaching 6v and a servo to the receiver It did link and function. No receiver ID as the quote states, but it is working. Thanks again.
