RCU Forums
-   Futaba Radios Direct support forum (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/)
-   -   9C programming (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/1691030-9c-programming.html)
rc-sport 04-04-2004 10:59 PM
9C programming
Bax, I need help. I looked in the manual and online and I can't remember how to assign a switch that will allow the both ailerons to deflect up when up elevator is applied past 50%. I want to use ths function for Harriers and such. I did this for another plane I had but I can't find the info again. Ohyea, I have the 9C radio.
Bax 04-07-2004 04:50 PM
RE: 9C programming
You'll need to do two mixes, one for each channel. Use the following FAQ, but use the elevator channel instead of the throttle channel, and then each of the two aileron channels instead of the smoke channel. Decide which switch to use as the on/off switch, and set both mixes to that switch.
http://www.futaba-rc.com/faq/faq-9c-q520.html
Hope this helps.
rc-sport 04-07-2004 07:46 PM
RE: 9C programming
Thanks Bax
