RCU Forums
-   Futaba Radios Direct support forum (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/)
-   -   8UAP and twin elevator servos (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/1798968-8uap-twin-elevator-servos.html)
Wildstyle 05-09-2004 03:59 AM
Hello
A flying mate asked me this, what program should I use when setting up twin elevator servos on my new Edge 540.
I tried a P-Mix combining channels 2 and 8 together, but the channel 8 knob has an affect when turned. Is there any way of Inhibiting the Channel 8 knob?
So basically my question is what program should he be using with twin elevator servos?.
the radio is a Futaba 8UAP.
Thanks Anthony[:-]
Krysta 05-10-2004 10:43 AM
RE: 8UAP and twin elevator servos
Hi Anthony,
Please check out our FAQ's for the 8U on our website at:
http://www.futaba-rc.com/faq/faq-8u.html
You will find the answer to these questions and a lot more helpful hints and info for this radio.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Wildstyle 05-10-2004 03:57 PM
Hi I was able to figure it out last night, Just used the Alvator program with AIL-3 and AIL-4 set to 0% and have ELE-2 and ELE-1 set to +100%.
No need for a y harness and no reversed servo problems.
bobswika 04-10-2006 10:26 AM
Hello,
Does anyone know if this disables the channel 8 knob? Thanks.
Krysta 04-10-2006 11:53 AM
Yes this does negate the channel 8 knob when this is activated:
Use the ailevator function, designed for just this purpose.
Plug servos into 2 and 8
Go to AILEVATOR
Make the function active
Test your elevator movement. If one is going the wrong direction, reverse the % for that servo (ie -100%).
IMPORTANT READ ME: Do you want your elevator servos to also act with your ailerons? If NOT, you must reset the AIL3 and AIL4 numbers to 0.
Sincerely,
Krysta
Futaba Service Center USA
ORIGINAL: bobswika
Hello,
ljones5000 04-14-2006 06:34 AM
I tried using the ailevator function on my 8U but ultimately just put in a "reverser" because one elevator half was lower than the other and I could never figure out why. I didn't do anything to the ailerons.
What did I do wrong?
Larry
