RCU Forums
-   Futaba Radios Direct support forum (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/)
-   -   Need Help in programming the Super 8 (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/2004062-need-help-programming-super-8-a.html)
Pile-O-Wood 07-19-2004 12:53 PM
Need help on dual elevator servo pgm. What channels do you use ,what mix do you use and if you use ch. 6 7 or 8 how do you disable the rotory knob?
Krysta 07-20-2004 08:32 AM
RE: Need Help in programming the Super 8
Hi Pile-O-Wood,
Please check out our FAQ's on the 8U at:
http://www.futaba-rc.com/faq/faq-8u.html
I am sure these will answer all of your questions.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Pile-O-Wood 07-20-2004 09:44 AM
Krysta, thank you, it works.
Krysta 07-20-2004 03:01 PM
Glad to hear it helped you out!
Have fun! Krysta
