RCU Forums
-   Futaba Radios Direct support forum (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/)
-   -   Polyswitch Question (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/221059-polyswitch-question.html)
Maxime 08-07-2002 12:56 AM
Polyswitch Question
I just sent my 8UAF in for service, and to have a polyswitch installed. Well there's a slight problem with the polyswitch: Whenever I try to cycle the battery (without removing it from the radio), the cycler shows that there's only 75% of the capacity in the battery. If I take the battery out of the radio to cycle it, then the cycler shows 100% capacity...
My question is: is this normal? Does the polyswitch puts a load in the circuit? If it is normal, then the polyswitch isn't very useful... Which is not a big problem with the 8UAF but it is with my 6XA (I ordered an extra polyswitch and installed it myself in the 6XA... same story about the cycling problem)
Thank you
Maxime 08-08-2002 01:54 AM
Polyswitch Question
I tried it again today with the 8UAF. This time it worked great. I believe there might have been something wrong with the connector I use between the cycler and the radio. Tomorrow I will try again with the 6XA, and let you know if it went well.
Thank you
Maxime 08-08-2002 08:10 AM
Polyswitch Question
Well it works with the 6XA too....
I believe I had a bad solder joint on my connector...
Sorry about this!
mr.rc-cam 08-08-2002 10:35 PM
Polyswitch Question
Any chance you used a higher discharge current when you were getting the disappointing results? If so, what current was it?
Maxime 08-09-2002 10:33 AM
Polyswitch Question
I'm using an old Digipace 1 with 300mah load. so no chance that was the problem. Now everything works fine after re-soldering the connector.
