RCU Forums
-   Futaba Radios Direct support forum (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/)
-   -   Choke setup on a 9Z wc2? (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/2382824-choke-setup-9z-wc2.html)
Ken Bryant 11-28-2004 01:22 PM
I am in the process of setting up my gasser plane and want to open and close the choke with a servo. I have a 9Z WC2 radio and wasn't real sure how to do this. Any suggestions would be nice.
THANKS
Krysta 11-29-2004 11:44 AM
RE: Choke setup on a 9Z wc2?
Hi Furyicon,
Are you wanting this on a switch or dial? I am assuming that this choke is just an on/off, if so doing a Pmix from the channel you have this plugged into, with the same channel as slave should work for you. Just select which switch or dial you want this on.
Thanks, Krysta
quist 12-01-2004 10:44 PM
I put the choke servo on Aux 8 and then went to the function menu to change the control to the left slider. It allows you a partial choke also. To adjust the servo throw to get the choke perfect go to the atv menu.
