Help with hovering throttle mix
I currently own a 9C transmitter and fly 3D. I am working on my low hovering and need help in setting up a throttle mix(curve). The goal is to have a relatively flat spot on the curve in the hovering band. I have review my 9c manual ,but I am lost on just where to start.
RE: Help with hovering throttle mix
The 9C transmitter does not have a throttle curve in the airplane menu. Only in the heli menu.
You can, though, use the D/R,Expo menu to adjust the throttle exponential curve. That may help. |
I looked and didn't see one, but was hoping I missed something. Don't think heli mode would work. Does the Super 9C offer it?
couldnt you just use one of the 5 point mixes??
Not sure, the one 5 point I saw was meant to link the throttle to another channel. I have some free mixes, but never a 5 point mix so it is all new to me.
I think you can make the throttle the slave and master and get a nice curve if you have a pmix open
Thanks, I will give it a try.
Hi there
I am looking for such curve as well, and according to the FAQ Futaba's website it's possible. Only they dont explain HOW! I just cant figure it out. rightflyer, if you had any luck, could you please explain what you did? |
You must use a Point mixer and expereiment to find where place these throttle points on the throttle curve. For instance, if your plane hovers at 1/2 throttle you would want the throttle curve nearly flat around mid-stick. You would then pick the points to make that happen.
We did some further checking after reading some more posts here.
Use pmix #6 or #7. They allow curves. Turn the mixer on, master is throttle and slave is throttle, link is off, and set the switch position to Null if you want this to operate all the time. Otherwise select the swithc and position you want. Now go to the page with the curve and set the points where you want them to get the throttle action you need. For all who've replied, thank you, but please be aware that this support forum is only for people who have questions and for ONLY Futaba support reps to answer. This is not an open forum where anyone can supply answers. If we make a mistake in our answer, it's OK to send a PM to let us know. We'll then fix our mistake. Only original posters can post follow-up questions to their original question. If anyone else has a question, they should start a new thread. Please be aware that replies to questions by non-Futaba reps will be deleted as we find them. That's RCU's rule for any manufacturer support forum. Thank you. |
| All times are GMT -8. The time now is 04:34 AM. |
