RCU Forums
-   Futaba Radios Direct support forum (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/)
-   -   crystal change (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/310459-crystal-change.html)
timrcpilot 10-11-2002 02:47 AM
crystal change
I just bought a Futaba 6XA (used) Tx, it is on channel 21.
I have an older Futaba 4 channel Tx and 7 channel Rx 127DF on channel 48.
I am going to retire my 4 channel Tx and use the Rx from it with the new 6XA Tx. Can I use the ch 48 Tx crystal in my 6XA Tx, or would it need re-tuned since it crossed from lo-band to hi-band?
Or do I have to buy a new channel 21 crystal for my Rx and keep the Tx on its original channel? Not my first choice, since the other method does not require me to buy a new crystal.
Tim
amcross 10-11-2002 02:33 PM
crystal change
Tim,
NEVER EVER change transmitter channel. that's a no-no.
Hi and low band refer to receiver only. You need to either:
a) have your 6X retuned, with new crystal to your high band channel; or
b) have your 127DF retuned to match the new transmitter's low band channel, with new crystal.
timrcpilot 10-11-2002 09:26 PM
crystal change
Thanks for the help AnnMarie !!
Just a few more questions. I think I understand it better now that I have read some of your earlier posts.
If I put a new channel 21 crystal, in my receiver (was 48) I should send it in to have it tuned, correct?
Does the age of the receiver matter, my receiver is an older one, in that I have had it for quite a while.
If I use another Futaba receiver that was on the lower channels, say less than 35, and put a new crystal in it, that is OK without having it sent in to be retuned, correct?
Tim
amcross 10-11-2002 11:16 PM
crystal change
Hi, Tim! You have it 100% accurate. No, age doesn't matter.
