Programming flaps on a Super 8
Hi Ann Marie!! I did a search for this question but didnt find anything so here I am:)
I have the super8 and I have flaps on a 60 size warbird. Currently I have the flaps plugged into channel 5 (retract channel).Do I need to move the flaps to another channel in the rcvr/ its an 8 channel rcvr? I want to have the flaps operate off of the 3 position switch( I think its the "C" switch). I would like the flaps to be fully closed when the switch is all the way up, about 30 degrees of flaps when the switch is in the central location , and full flaps when the switch is all the way down. Now I would also like to mix in some down elevator with the flaps. Is the previous setup going to work with the elevator mix? Thanks for any help you could provide!!!!:) John McGowan |
John,
Please see the FAQ at www.futabarc.com/faq/faq-8u.html. the first 2 FAQs will give you exactly what you want. then just do a flap to elevator mix afterward to add your elevator. |
| All times are GMT -8. The time now is 10:43 AM. |
