Throttle 'Boost' Function possible?
Hi,
I have a FF6, with a 9c on order I have an electric model, which draws very nearly the motors maximum rated current at full throttle. What i'm trying to achieve is 90% throttle at max throttle stick, but by flicking a switch, override this to 100% throttle. Could I do this with a Mix and use channel 5 as Throttle? Regards, Steve |
Hi, Steve!
9C can do this easily. 6X cannot. For 9C, do a throttle to throttle mix at -10%, on the high side only, with the desired switch as the trigger. This will give you your 90% when the switch is pulled, adn give you your 100% when the mix is off. |
Thanks AnneMarie!
9C Radio arrived earlier this week. Programmed the mix as you suggest and it works a treat! I didn't even need to look at the Manual!! Setup 8 models, 4 being acros with complex mixes within an hour! This is one great Radio! Thanks again, Steve |
| All times are GMT -8. The time now is 09:42 AM. |
