specs for current draw on servos
Just wanted to know what the current draw specs were for you standard s3003 servos and why this important fact isn't listed anywhere. thanks.
RE: specs for current draw on servos
Hi RC-FIEND,
The servo current drain depends on the load but under normal servo operation a servo will draw between 1 and 2 amps when stalled. At idle it will draw about 15 milliamps. I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721. Sincerely, Krysta Hunt Lead Futaba Customer Service and Programming Technician Futaba Service Center USA ORIGINAL: RC-FIEND Just wanted to know what the current draw specs were for you standard s3003 servos and why this important fact isn't listed anywhere. thanks. |
| All times are GMT -8. The time now is 01:53 PM. |
