RCU Forums
-   Futaba Radios Direct support forum (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/)
-   -   7CAP Twin Engine Setup (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/5439012-7cap-twin-engine-setup.html)
sdcranford 02-18-2007 10:09 PM
So, I'm sure I already know the answer to this but need proof that I made a mistake not buying the 9CAPS over the 7CAP.
Here goes...I just finished my twinstar and set up a mix for the throttle. One side master and the other side is a slave.
Just discovered the trim does not work nor does the throttle cut.
I am sure I know the answer because my UCD had an issue with the twin elevator servos.
So, my question..is there a way to make the twin setup work as far as the trim and throttle cut.
I think it is terrible Futaba didnt include this in their programming...which we all know they could do so. They did this so
we buy the 9CAPS.
So, now I have a 7CAP that is useless because I want to be able to set my end points on each engine servo seperatly,
and would like to remove the Y-Servo reverser from my UCD.
Now I will be seeking a 9CAPS Tx only, and if I didnt already have several futaba Rx's I would switch to JR.
Bax 02-21-2007 05:02 PM
RE: 7CAP Twin Engine Setup
In the 7C transmitter, slave channels of mixers don't get the benefit of the trim of the master channel.
The Throttle Cut function only works with the throttle channel. In fact, it only works that way in the 9C. In the 9C, to get a second channel to cut when you flip the switch, you have to use an offset mix set to the same switch on that channel.
All this is on the FAQ page for the 7C system.
