9C--how to activate idle ups?
I just bought a 9C for my heli. How do I activate switch E to switch between normal and the idle up modes? I've progammed the pitch curves in them, but can't get the (NORMAL) indicator to change when I move the switch.
Thanks |
I just discovered how to do this, but can not get my Logo10 model in Aerofly to give -ve pitch:confused: so no inverted flight!!
Anyway.. go to advance heli menu thr-curve. Use the select button to go up to NORM and rotate the dial. IDL1 or 2 or 3 will show and then you can go down to MIX and change the INH to OFF. This then changes when you move the E switch. It enables the Thr and Pitch curves at the same time. Jeff |
| All times are GMT -8. The time now is 01:08 PM. |
