RCU Forums
-   Futaba Radios Direct support forum (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/)
-   -   10CAP Reverse Elev servo using mixing (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/7672672-10cap-reverse-elev-servo-using-mixing.html)
Big_Bird 06-28-2008 10:07 PM
I have a new 10CAP and I want to use channel 2 and channel 6 to reverse one of the two elevator servos using a MIX function.
Big_Bird 06-29-2008 05:44 PM
RE: 10CAP Reverse Elev servo using mixing
I kept working at it until I found out how to do it.
Go to the Advanced Menu and select Prog. Mix1-8
Select an unused mix. Example: Mix 1
Turn MIX>ON
Turn TRIM>ON
Turn LINK>ON
Set POSI>NULL
Set MASTER>CH2
Set SLAVE>CH6
Set RATE^>-100
Set RATEv>-100
End End
In Basic Menu select >AUX-CH
Set CH6>NULL
End End
