RCU Forums
-   Futaba Radios Direct support forum (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/)
-   -   AMP Limits For 6014 Receivers (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/8769402-amp-limits-6014-receivers.html)
storklappe 05-14-2009 06:06 PM
Hi Mr. Baxter,
Can you tell me what the max current rating is on the 6014 receivers. I just read on another site that quotes you saying the number is 8 amps. I found this hard to believe when the competition has their top-of-line receivers rated at over 30 amps. I thought it would be best to ask you rather than beleive some unknown guy quoting you.
Thank you.
Bax 05-15-2009 09:23 AM
RE: AMP Limits For 6014 Receivers
8A is the max rating. We'd tend to not believe 30 Amps on a circuit trace, unless it's very thick or very wide. Many times, that rating is an instaneous burst of very, very small duration.
BaldEagel 05-16-2009 09:37 AM
Using the MPDX-1 system it would be possible to pull 8 amps through one servo outlet, if you got to 1amp per servo, especially if you where using the MPDX1 to power a four servo per side aileron on a giant scale, is this permisable?
Mike
