4 servo elevon trim problems
Hi
Im setting up the elevons on my hotspot with 4 servos. Im using the method stated here: http://www.futaba-rc.com/faq/faq-9c-q510.html , but I cant seem to get all 4 servos to trim when trying to trim the aileron part. Only the 2 outboard servos move when i trim aileron. If i trim elevetor, then all 4 servos move. Anyone run into this ? I guess it would be ok to only trim the outboard elevons ?? http://bornholm.adsl.dk/modelfly/fil.../Dsc00592s.jpg SJ. |
When you activated the Pmix, did you turn TRIM on? That would let the mixer know that the slave channel gets trim information from the master.
Thanks Bax, but I found another solution.
http://www.rcuniverse.com/showthread...932&forumid=26 SJ.. |
| All times are GMT -8. The time now is 05:42 AM. |
