RCU Forums
-   Futaba Radios Direct support forum (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/)
-   -   12FG and Flaps Function (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/9258963-12fg-flaps-function.html)
nxtdoor 11-16-2009 09:04 PM
Have my 12FG and 6014 set up as 2Ail/2Flap/Ailevators for my jet with flaps on a 3-position switch. I have the flap1 servo adjusted in AFR with a point curve set so the middle switch position is where I need the flap to be for takeoff and bottom switch position as landing flap . I also slowed the servo speed in AFR. Problem is flap2 has no means to adjust it in the AFR menu to the same settings.
What am I doing wrong?
Jeff
Bax 11-17-2009 04:57 PM
RE: 12FG and Flaps Function
Normally, flaps are set up so that one endpoint is "up", the middle point is 1/2-flaps, and the other endpoint is full-down. So you set up the AFR as desired, and use the sub-trim to adjust he center point (1/2-flaps), and the endpoint adjustments to adjust the up and full-down positions.
nxtdoor 11-18-2009 02:44 PM
I setup as you described but forgot to use the subtrom and endpoionts. I went straight to AFR first. that was my mistake.
There is an inherent flaw in these new radios; too much many ways to screw them up!
Thanks for waking me up to basics.
Tony Babington 11-23-2009 05:38 PM
I have a problem setting up my 12fg with the 14 channel receiver. I have an old Kangaroo delta airframe which has two independant control surfaces on each wing. The instructions say they must work in tandem as aileron/elevators, I think that the model is designed this way for redundancy. I have set the radio up so that the control surfaces work off channels 4;5;11;and 12 this way I can adjust each individual servo so that the throws match. I now wish to creat a condition in the radio so that the inboard surfaces can be drooped by a few degrees to act as flaps for take off. I cannot find a way to do this. the most obvious way I thought was to put some sub trim on the inboard servos, this does not work because the sub trip then acts on condition one and two. Any ideas would be appreciated
nxtdoor 11-24-2009 09:56 PM
I would just create another condition. You probably need to "ungroup" some of your controls so they don't react the same in other conditions.
Bax 11-25-2009 09:59 AM
Set up a condition where you have some offset in the AFR for the flap channels. When you go into the AFR section, you can see the mode, which is set to EXP1, EXP2, or POINT. To the right of that is the offset. Just adjust it a bit up or down, and your flap channels will then re-center to the offset position you set. Make sure the AFR is set to "SINGLE" on the second page where the heading is "Group".
Tony Babington 11-26-2009 02:51 PM
Hello Bill,
I don't know if I am understanding you properly but I have set up the plane as 'Wing' two ail' rudder normal. In the function menue CH 4 is aileron CH 5 is Aileron2 CH 11 is Aileron2 and CH12 is Aileron. In AFR there is therefore no Flap channel available. Any offsets I put in appear to affect all four surfaces not just the inner two. Thanks for your help. Tony
Bax 11-30-2009 03:34 PM
We'd set up the model so that it's a 2-flap, 2-aileron model, then set up the conditions as described above.
