RCU Forums
-   Futaba Radios Direct support forum (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/)
-   -   8FG SD card use (https://www.rcuniverse.com/forum/futaba-radios-direct-support-forum-125/9755686-8fg-sd-card-use.html)
malcolmholt 05-24-2010 10:10 AM
8FG SD card use
I have installed and formatted an SD card but the manual offers no explanation of what purpose this serves or how to use it. It advises the use of http://futaba-rc.com/sellsheets/downloads.html but this page seems unavailable. I assume the card should allow me to store model data and download software updates but I would welcome some guidance on its use. Thanks.
Bax 05-24-2010 01:15 PM
RE: 8FG SD card use
Use of an SD card will expand the number of models you can create and store. It will also allow you to download software updates whenever Futaba may make them available. To date, there hasn't been an update to the original software.
Here's where you'd check for new software updates:
http://www.futaba-rc.com/downloads.html
Movie man 02-26-2011 02:57 PM
RE: 8FG SD card use
I have placed an SD card in my transmitter. It formatted the card. I went online for the update. I downloaded the update and tried to install it into my SD Card. Numerous attempts to load resulted in the promt that the card was full. What am I doing wrong? Is this a bad SD disk or what? When I check the SD disk, it says it is empty, but when I attempt to download it says not enough memory.
Anyone have any suggestions and/or has anyone out there had this problem? Would like to hear from you.
Bax 02-28-2011 07:03 AM
RE: 8FG SD card use
You need to download the file system utility software: http://www.futaba-rc.com/downloads.html
Use it to install the software onto the SD card.
hillbillyexpress 03-05-2011 08:10 PM
RE: 8FG SD card use
i am alos having this issue ? i did the file system utility but cannot figure out hoe to transfer the update to the sd card, the instructiond dont say how, they tell how to import and export models. please help bax, this is driving me crazy
Bax 03-08-2011 07:47 AM
RE: 8FG SD card use
Here are the installation instructions:
http://downloads.hobbico.com/softwar...g_T8FG_ENG.pdf
hillbillyexpress 03-08-2011 08:21 AM
RE: 8FG SD card use
Bax, I did that, but i did figure out my problem and would like to share, i was using google chrome. it would not work no matter what i did. when i tried to do the download via internet explorer, it worked on the first try.
Free Bird 03-08-2011 09:04 AM
RE: 8FG SD card use
I updated my 8FG this past weekend and it went well. I do have a question though. If I save my current models on the same card, does the system reload the upgrades everytime I reload a saved model? This is the first time I've ever used the internet/computer to work with a Tx.
FB
Bax 03-08-2011 11:20 AM
RE: 8FG SD card use
Your transmitter will upgrade the software only when you have the upgrade switch moved and then the transmitter turned on. Just adding or rearranging models does nothing to the software. The software on the card is only used when you specifically select the software upgrade process.
Free Bird 03-13-2011 11:24 AM
RE: 8FG SD card use
Excellent! Thanks Bax!
FB
