DA 50 Plug Cap
My Feedback: (10)
CA
DA 50 Plug Cap
I recently damaged the spark plug cap on my DA 50 in a nose over. Actually it removed it completely leaving just the plug wire itself. I have repair kits, but was unsure if DA uses a resistor in line before the spark plug, it looks like resistor plug wire, which would negate the use of the resistor, but since the repair kits I have contain the resistor, I was unsure whether to use it or not? Anyone know?
Thanks.
Thanks.
RE: DA 50 Plug Cap
ORIGINAL: rslstft
Thanks.
Thanks.
Use the resistor ONLY when the plug wire is made of metal.
Insert a piece of metal rod with same length as resistor instead.
Regards
My Feedback: (19)
RE: DA 50 Plug Cap
ORIGINAL: av8tor1977
It was my understanding that the resistor was needed only with non-resistor plugs. Is this wrong??
AV8TOR
AV8TOR
