Smog Muffler for DL30 Engine
Old 10-16-2010 | 10:44 AM
Default Smog Muffler for DL30 Engine
Has any one used this muffler? I am trying to decide if I should get the J-TEC Pitt muffler or this SMOG muffler.
http://www.himodel.com/engines/Smog_...0_Engines.html
The stock DL 30 muffler is a pretty much a straight pipe. On the outside, the Smog muffler look pretty much the same?
jsflysrc
Old 10-16-2010 | 11:59 AM
jedijody's Avatar
Default RE: Smog Muffler for DL30 Engine
It is the same, it's actually a stock CRRC GF26I exhaust which is almost exactly the same as the DLE30 exhaust. They call it a Smog muffler because it has a smoke nipple, if you want smoke you would much better off with the Jtec pitts.
Old 10-17-2010 | 10:20 AM
Thanks. I will go with J-Tec. I don't know what they are thinking when they designed that muffler.
Old 10-17-2010 | 07:43 PM
ORIGINAL: jsflysrc
<hr />My guess they was thinking "lets not make them"...we will buy parts cheaper &amp; not have the hassle of making them. Kinda like farming out things like the they do here in the USA. I would say some manufacturers of these engine make only the big chunks. Like the crank case,piston, crankshaft, reed blocks and maybe the con rods.
A lot of the other parts I bet are made elsewhere. Like piston rings, bolts, carburetor's, ignitions, most all electrical parts, spark plugs, ect. Do not be surprised if some time you find out some parts are made in India! Like the Royal Infield Motorcycle!
Capt,n
