New form of Gas ignition
Super charging adds cylinder pressure,and then some!
TOM, I was refering to spark engines in cars....you did talk about turbos in your last post & a lot of data that refered to all sizes & types of engines. Sorry I read it wrong. Capt,n
I think I misunderstood you as well. No big deal on my side. Hope I didn't catch you on a one off thing as well.
There's a subtle hint in that article for people that have engine bearing issues, and it's just as subtle for the companies that perform warranty work. Evidence of detonation is usually visible, and someone that returned an engine for warranty work with that evidence present might want to reconsider asking for free warranty repairs This is one of the reasons I don't get excited too early when I read about people new to gas engines experiencing a bearing failure. I figure about 30% of them forced it to happen.
I look for clear evidence of detonation in every bearing failure I see, it has been present in several instances but it's never what you're used to seeing in say a motorcycle engine, outboard, or even an automotive engine where the edge of the piston is blown away down to the ring or a hole clear through thepiston half way between the edge and the center of the dome. It's very subtle and looks like a gray dusting ina localized area at theedge of the piston with a corresponding area of similar appearance in the squish band. What it actually is, is an area where the carbon has been blasted off ofthe metal of the piston and at the squish band, using a magnifying glass you can actually see very small pits in the aluminum.
When it comes to engine failures possibly caused by detonation, in the engines I've worked on it would bea very thin line to walk on. The evidence ofdetonationhas beenso subtle it's hard to label it as the precursor to a disintegratedbearing, mainly because almost NOBODY understands exactly what detonation is let alone the forces that are actually involved and how those forcesrelate to parts of the engine far away from the epicenter of the actual event. It would definitely be a very hard sell to most peoplefacing paying for a crankshaft replacement.
BTW Pat, that is a jewel of an article and this is a very good place to post it, kudos for you!
AV8TOR
As far as the bearings go, eliminating the cages allows the use of more rollers, more rollers allows the load of the forces to be dispersed over a larger area and a greater number of individual rollers rather than just one or two. Only the most intelligent designers use this bearing method, it's not difficult to install a full roller bearing but in manufacturing it takes less time to slap a caged roller assembly on a shaft than using grease to hold the individual needles in place for assembly. Considering the skill level of most of the Chinese assemblers I'm sure the caged bearing may actually cut down on the number of warranty problems that could be caused by not having enough needles in a bearing surface.
My friend had a book on ''Super Tunning'' and it was the most in-depth book with every aspect possible. I wish my eyes was better....I would borrow it. I think in general short stroke spark engines are less prone to spark nock...or pre-detanation. Capt,n
There is no such term as predetonation. There is preignition and then there is detonation. One leads to the other, but no predetonation.
Ed Cregger
All high output engines are prone to destructive tendencies as a result of over boost, misfueling, mis-tuning and inadequate cooling. The engine community pushes ever nearer to the limits of power output. As they often learn cylinder chamber combustion processes can quickly gravitate to engine failure. This article defines two types of engine failures, detonation and pre-ignition, that are as insidious in nature to users as they are hard to recognize and detect. This discussion is intended only as a primer about these combustion processes since whole books have been devoted to the subject.
First, let us review normal combustion. It is the burning of a fuel and air mixture charge in the combustion chamber. It should burn in a steady, even fashion across the chamber, originating at the spark plug and progressing across the chamber in a three dimensional fashion. Similar to a pebble in a glass smooth pond with the ripples spreading out, the flame front should progress in an orderly fashion. The burn moves all the way across the chamber and , quenches (cools) against the walls and the piston crown. The burn should be complete with no remaining fuel-air mixture. Note that the mixture does not "explode" but burns in an orderly fashion.
There is another factor that engineers look for to quantify combustion. It is called "location of peak pressure (LPP)." It is measured by an in-cylinder pressure transducer. Ideally, the LPP should occur at 14 degrees after top dead center. Depending on the chamber design and the burn rate, if one would initiate the spark at its optimum timing (20 degrees BTDC, for example) the burn would progress through the chamber and reach LPP, or peak pressure at 14 degrees after top dead center. LPP is a mechanical factor just as an engine is a mechanical device. The piston can only go up and down so fast. If you peak the pressure too soon or too late in the cycle, you won't have optimum work. Therefore, LPP is always 14 degrees ATDC for any engine.
I introduce LPP now to illustrate the idea that there is a characteristic pressure buildup (compression and combustion) and decay (piston downward movement and exhaust valve opening) during the combustion process that can be considered "normal" if it is smooth, controlled and its peak occurs at 14 degrees ATDC.
Our enlarged definition of normal combustion now says that the charge/bum is initiated with the spark plug, a nice even burn moves across the chamber, combustion is completed and peak pressure occurs at at 14 ATDC.
Confusion and a lot of questions exist as to detonation and pre-ignition. Sometimes you hear mistaken terms like "pre-detonation". Detonation is one phenomenon that is abnormal combustion. Pre-ignition is another phenomenon that is abnormal combustion. The two, as we will talk about, are somewhat related but are two distinctly different phenomenon and can induce distinctly different failure modes.
The above is good too read also. Capt,n
If you inspect an engine and find yellow or yellow-orange deposits on the piston dome, that engine has experienced an abnormal combustion condition known as detonation. In this situation, combustion begins normally with ignition from the spark plug but as the flame front moves across the combustion chamber, rather than burning smoothly, the unburned portion of the charge spontaneously ignites. This results in extremely high temperatures and a shock wave heard as "pinging." What has happened is combustion has been completed in about 29 degrees or crankshaft rotation instead of the normal 50.
The oxide of calcium, an element found in 2 - stroke oil additives, is normally near white in colour. At temperature very near that of the melting point of the piston, the oxide will change colour from white to yellow-orange and is an indicator that the engine was overheated. The excessive heat results in rapid piston expansion and possible failure of the lubrication film.
If this new gas ignition that Enya has developed works as planned....you will not need any CD unit, Switch ,extra battery, timing pick-up for ignition and the dreaded glitches cause by CD system will be gone forever. Here is a link to a similar system....more on the Enya layer. Capt,n<hr />http://www.smartplugs.com/engines/2stroke/
http://enya-engine.com/180XGS_E.html
This engine will have zero sparking noise! A real big advantage!!!!!
It looked like from one of the descriptions, that the catalytic plug is a single speed device. If one wants to use it in variable speed applications, some type of electronic goodie is needed to make it work. This "Ignition Module" if you will, may require electicity to work, I would guess, and some type of rpm sensor to effect corrected timing
Enya's 180 gas engine will be interesting to watch out for. It appears designed much closer to square than the other 180 gas engines of today.
Nevertheless, interesting stuff
The auto manufacturers tend to try to use other means to limit detonation because the fuel mix trapped in the quench area often does not burn completely and hurts both fuel economy and emissions. Long rod/stroke ratios and the increased piston dwell time they cause seem to lower octane requirements and many engine designs today follow that trend, along of course with fuel injection, knock sensors, computer controlled timing, etc.
AV8TOR
Squish is still quite important in small two strokes. Emphasis on small. When EFI enters into the equation it becomes even more importan, critically importantt-in small two strokes. Then you have squish angle, along with piston dome, combustion chamber shape relationsips to impact things even more.
No arguement from me becuase what you say holds very true to form in larger engines. The smaller two strokes have such small bores that squish remains pretty important to them. Seems with the 100cc (twin 50) and under injected group it plays pretty large in the combustion process. For those that thought they saw something they liked in that last sentence, don't go there cuz it ain't happening for RC.
Sorry Ed, thought it was you. I should have gone back to be sure before typing. My bad.
