Choosing the right engine
Hello,
I'm starting to build the BH Gilmore Red Lion 50cc ARF and I wonder what engine to choose.
Being on a tight budget, what would you chose between:
1) GF55II 55cc twin
2) MT 70cc Twin
3) DLE-55 55cc
The plane weight is aprox. 13 lbs.
Thank you !
PS: I read all the debates (well, almost) regarding the above mentioned engines.
1) GF55II 55cc twin
2) MT 70cc Twin
3) DLE-55 55cc
Thank you !
AZ
I bought the DLE 55cc from Tower Hobbies for $410 - $60 member's coupon for total of $350. I ran close to three gallons of fuel 32:1 mix thru the engine so far and no deadsticks. I recommend to choke on first start with ignition on then choke off and then real start. Otherwise with choke on and ignition off like in the manual, the engine can become flooded. I'm very happy with the engine, had it run with suboptimal needles setting and it just chugged along. Vertical on 21lb plane is unlimited but not ballistic. I don't have the other engines so I can't compare but I'm 100% happy with the dle 55cc engine.
ORIGINAL: paof
DA 50 OR MVVS 40
DA 50 OR MVVS 40
For a nice scale project like the Gilmore, I would personally stick with something like the MVVS rather than the DLE55 some have suggested. You will get better low-down torque out of the MVVS which in my book lends itself better to scale applications. If you stick a pipe on the 40, you will also get a very nice quiet setup (if there is any such thing)
I'm in no way knocking the DLE, it's just my personal view.
ORIGINAL: pe reivers
mvvs40
mvvs40
Did the OP ask for MVVS engines ?
How much do you earn for the SPAM here ?
IF You dont like this thread GO AWAY to your forum.
Hello - what muffler do you recommend for a scale look if using the MVVS 40 ? I'm lost between product numbers and codes on mvvs.nl.
Thank you.
Thank you.
Check out petrol engines in the left info bar
Then select the item you want in the top shop bar.
ORIGINAL: codedlanguage
Thank you.
Thank you.
