Kavan Engines
Wow these things have gotten a lot cheaper!
In 1988 they where $995
Now they are only $7,500
In 1988 I'd have had to work 430 hours to get one. Now I only need to work 300 hours to get one.
http://www.mecoa.com/kavan/index.htm
This engine has its own oil supply in crankcase that has a magnetic drain plug. Also a dip-stick to check oil level & a plunger type oil pump to move oil to where its needed. The more expensive model has spark (CD) ignition. I found another photo below!</p>
