new engines!
Old 12-21-2010, 03:08 PM
mpascual
Default RE: new engines!
ORIGINAL: a1pcfixer
ORIGINAL: mpascual
New comming gas engines , 8 cc, 17cc, 25cc, 35cc ..... will change our perspective.
Regards
Some of us are aware of a 9cc coming, but who's releasing an 8cc?
Between 8 and 9 cc, sorry.
Regards
Old 12-21-2010, 06:27 PM
dubs1946
Hi so the DJ 80 from SDS hobby is the MT 80 in disguise.
I am in the market for a 80-85cc engine.
Has anyone any information on the old MT80 or the now DJ80 on there use as i have never heard os either before and no nothing on them, it seams there is a hole in the market when it comes to large single cylinder engines and as always the Chinese are trying to fill it.
Thanks Dave.
Old 12-21-2010, 07:55 PM
apalsson
apalsson's Avatar
ORIGINAL: dubs1946
It was a vibrator!!!
Even worse than the original DA85
There are several good 80cc out there including ZDZ, MVVS, 3W and the new DA85 (after updates)
Personally - and assuming that each time a product is cloned, it's marginally worse, I wouldn't spend $$$ on a clone of the MT80
Old 12-21-2010, 08:23 PM
Tired Old Man
ORIGINAL: apalsson
[sm=thumbs_up.gif] I guess the thumbs up emoticon doesn't work anymore...
Old 12-21-2010, 08:42 PM
w8ye
My Feedback: (16)
w8ye's Avatar
Old 12-21-2010, 09:12 PM
  #31
Tired Old Man
All I see when I bring up the "more smilies" window is a bunch of exxes.
Old 12-21-2010, 09:15 PM
  #32
w8ye
My Feedback: (16)
w8ye's Avatar
I have a Toshiba lap top running Ubuntu and Firefox
I think the new adminstrator, ib-dick, uses an Apple with Leopard and Safari.
Old 12-21-2010, 09:35 PM
  #33
aussiesteve
aussiesteve's Avatar
ORIGINAL: w8ye
ROFLMAO
With the "issues" seen since the recent upgrades etc, I suspect "IB" has taken nothing more than a rock with him on his Safari.
Old 12-21-2010, 09:43 PM
  #34
w8ye
My Feedback: (16)
w8ye's Avatar
There does appear to be some rendering problems depending on your operating system and which server you happen to get attached to.
Old 12-22-2010, 12:42 AM
  #35
Tired Old Man
Someone needs to get with the program. Although Apple has more powerful web and media tools, Microsoft still dominates the universe.
Old 12-22-2010, 04:38 AM
  #36
rmh
rmh's Avatar
Probably few -if any of the tiny gasser fans know- back about 60 odd years ago there were some pretty good performing gasoline engines in .60 cu.inch- The racing versions of McCoy were an example
These had to rev to make power - as will any very small gasser.
You will never see the same power available using alcohol and nitro methane but obviously, max power per pound is not the criteria.
Old 12-22-2010, 06:32 AM
  #37
Super08
Super08's Avatar
ORIGINAL: apalsson
ORIGINAL: dubs1946
Not only was it a vibrator it had no power. The porting was wrong, didn't seem to matter what prop was put on it the engine would run out of breath at around 5700~6000.
Old 12-22-2010, 08:21 AM
  #38
cloudancer03
My Feedback: (22)
I have sold all my 2stroke engines .I began gravitating to electric when I went to florida for the winter.I couoldnt build in our condo and my family hated the smell of the engines stord inside.so I tried some electrics and found flying just as fun.I still have my 4 strokes and wont ever part and continue to use my satios.I did buy my first 30ccdle and love it.I may even get a 50cc and a 20cc over the next year or so.for me just a matter of prefernce.I dont go with big gassers although I tried it with a 3W 60 on a giant stinger.it was ok but going big is big on my wallet too and hard to transport.so the smaller gassers are good and affordable.I fly 3d on my 3dhobby electrics nothing like it.but I have gas for my warbirds.
the great thing about rc today is the diversity and choices you can make.
Old 12-22-2010, 09:12 AM
  #39
rmh
rmh's Avatar
What some fliers don't factor in, is that electrics can be built much lighter than models which have to absorb the pounding of a engine which apply power in a short burst each revolution.
No matter how well balanced the engine may be - the power pulses are what beat the airframe.
But - noise is a big factor for some- they want it!
Years back - the turbine engine was banned from Indy racing - no noise and potentially far more power .
The fans would have stayed away in droves
The NASCAR stuff runs wide open exhausts - -the fans LOVE it
Old 12-22-2010, 09:22 AM
  #40
Super08
Super08's Avatar
When an engine vibrates so much it breaks the heads off the screws used to hold the test stand down it is too much.....
Old 12-22-2010, 11:02 AM
  #41
Tired Old Man
Gotta agree with you Dick.
Going to a drag strip to see and "hear'electric cars would just never do. Even the jet vehicles don't have the aural satisfaction of a 3,000 HP IC engine on open stacks.
Old 12-22-2010, 12:07 PM
  #42
airraptor
My Feedback: (66)
A1pc i dont think you will ever find a gas engine that is the same weight, same power and same size of one that is run on glow.
Old 12-22-2010, 12:36 PM
  #43
a1pcfixer
My Feedback: (7)
a1pcfixer's Avatar
ORIGINAL: airraptor
Same, same, same??? Not my words.
When something like the DLE20cc closely matches weight with an equivilant glow, yet costs far less, and has less slime output, and has equal power, then it's game over....the mini gas wins!
Factor in the lower fuel costs of gas vs glow fuels, and no need of glow driver, glow starter, it just keeps getting better!
Old 12-22-2010, 12:58 PM
  #44
rmh
rmh's Avatar
The REAL power setup is one everybody ignores
Take a really well designed glow engine and put a spark ignition on it - run it on a alky/syn oil mix
The spark setup allows for extremely low idle with no flame out on recovery
Top power ?
you can compress it to a very high setting and then adjust mixture and spark to optomize it
On the tuned pipe setups I did this way - power (really constant usable power ) exceeded my glo setups running 20% nitro
fuel tank has to almost a large as a regular higher rnitro setup -which is almost double a gasoline setup.
But you end up with a setup which does not need a starter - or glow plug battery and NO flameouts.
PS -if your idea of a great ignition engine is one of the 199.95 variety - ignore this approach-
Old 12-22-2010, 02:41 PM
  #45
a1pcfixer
My Feedback: (7)
a1pcfixer's Avatar
ORIGINAL: rmh
The REAL power setup is one everybody ignores.....................................
I'll agree with those.
