ZDZ Engine Mount Templates (60-RV & Super 80J
Does anyone have, or know where I can get / download the engine mounting templates for a ZDZ 60-RV and a ZDZ 80J (Super 80). I looked on TBM website and all that I found was the mounting bolt hole dimensions. I wondered if there was cut-out templates out there for the carb going thru the firewall as well.
Thanks!
Kevin
Thanks!
Kevin
My Feedback: (14)
MO
RE: ZDZ Engine Mount Templates (60-RV & Super 80J
Here is one for the Super 80 in .pdf format. The carb must be removed and re-installed after the engine is mounted. Otherwise you will have a really, really large hole in the mounting plate to clear the complete carb.
Check the hole pattern to make sure it is printed out to the correct scale.
