Da-50 could be innocent - knocking/crackling sound during hover
I bought a used 30% yak with da-50 on it. It has been flown for almost 3 seasons (3d flying).
The other day, and during a hover, I heard a knocking or clicking noise which I thought in the beginning some guy at the field was knocking something with a hammer but then realized it was coming from the engine. I also thought something could be loose in the frame then landed and checked the plane, and there was nothing loose. Everything is fixed firmly. I flew again, and during the hover, I heard the same sound again.
Should I be worried about this sound?
Could it be the fuel-oil mix. I have a 50:1 mix of unleaded gas/sythytic oil. I am using the same fuel which was mixed a year ago and stored inside room temperature for months. Could this be it?
I would appreciate any opinions on this issue!
Thanks in advance!
Thanks in advance!
NJ
RE: Da-50 could be innocent - knocking/crackling sound during hover
Check prop bolts,when they start to losen it shows up in hover I have found a few times,good luck.
ORIGINAL: skip1320
Any other possibility?
Thanks.
I'd be VERY worried about the sound. You're burning your engine up through lean mixtures, poor prop sizing, bad cooling airflow, or any combination of those.
A crank can be broken and main bearings can be severely damaged through detonation.
send to DA cause they offer warranty on engines...but not in the airplane and electronics..which is the real money is after a crash.
My Feedback: (19)
ORIGINAL: Tired Old Man
ORIGINAL: q8cub
...Could it be the fuel-oil mix. I have a 50:1 mix of unleaded gas/sythytic oil. I am using the same fuel which was mixed a year ago and stored inside room temperature for months. Could this be it?
Thanks in advance!
Thanks in advance!
I would suspect the fuel, it being that old. Unless it has had some stabilizer added. That little oil combined with stale gas may be the problem.
I would try some fresh fuel with good oil at a higher oil percentage.
It may be too late, if you are hearing knocking; pinging may be a transient condition caused by the fuel. JMHO.
Good luck.
Sincerely, Richard
The affects of excessive knock are accumulative. A slightly lean condition may not be readily apparent but componenets inside the engine are repeatedly experiencing impacts of the condition over hundreds of thousands of revolution cycles.
Old fuel may have octane degradation as Spaceworm noted. Change gas and perform some tuning.
On my original DA50 the wrist pin loosened up in the piston causing a sound similar to what you are describing. (That was after just over a year of hard 3D with two different people bashing on it, er I mean flying it) Replacing the wrist pin, piston, ring and upper rod bearing got me another year and a half before the crank, rod and lower bearing had to be replaced. The crank main bearings were replaced at that time and it remained nice and tight until sold. Still running great last I heard.
Sorry guys but I discovered an issue that could be related to the crackling sound during hover: Landing gear shoe screw loose.
I just noticed one of the landing gear shoes screws was loose (more than half of the screw was sticking out of its place). I had a chance today to speak with the guy who sold me the yak. He confirmed that landing gear shoe could be the source of the knocking sound (sounded like piece of metal).
I will test it tomorrow and see how it goes.
Thanks again.
Thanks again.
Did a test today, and did not notice the same sound I described earlier. I did tighten the "loose" landing gear shoe screw which I think was the reason for the knocking sound. I need to do another test to confirm this.
Once 100% confirmed I will report this back here.
Thanks guys for the help.
ORIGINAL: q8cub
Did a test today, and did not notice the same sound I described earlier. I did tighten the ''loose'' landing gear shoe screw which I think was the reason for the knocking sound. I need to do another test to confirm this.
At Top Dead cente - the prop will have a little loose feeling (prop can move a little left to right as yo u gently twist the spinner back and forth
if it feel s "free" for a inch or so - you may have pounded out bearing.
