NEW TO GASSER CARB ?????
My Feedback: (7)
I just purchased a DLE 20 to put on a big stick and was wondering if it is ok to turn the carb over. I am mounting the motor cylinder down and the hookup for the servo would be better for my setup if the carb was turned on top.
Is this a problem?????
RE: NEW TO GASSER CARB ?????
Insure that the pulse hole still lines up (some have two, either one will work) and the gasket still allows the holes to be open. and it should be perfectly ok.
Sincerely, Richard
Sincerely, Richard
The DLE20 carburetor can be rotated in either position without worrying about the pulse hole, you can turn the carb and reed block or just the carb, or just the reed block, or just the gasket, it doesn't matter. If the bolts go through the bolt holes in all the parts, everything will line up and work properly.
VA
So to be clear does that mean you can turn the carb and reed block or just the carb, or just the reed block, or just the gasket?
Just KIDDING! Really!
Geez, can't you take a joke?
Also be sure to turn the attachment screws the right way in a multidirectional pattern one at a time but one 1/16 th turn at a time untill your sure contact has been super-imposed into place. Wait for the crush of the gasket is considered to be steady. Remember lefty = lucy & righty= tighty & vica verasa. If you forget just remember...if you do not get thigs just right...engines are self healing. But be carefull..your fingers tend not to grow back. Just Lizzard tails do that ! Maybe that Geco Lizzard on the TV comercial could give you a hand? You know...the one called $tanley. Well hop to it mate...times-a wasting!
ORIGINAL: captinjohn
Also be sure to turn the attachment screws the right way in a multi directional pattern one at a time but one 1/16 th turn at a time untill your sure contact has been super-imposed into place. Wait for the crush of the gasket is considered to be steady. Remember lefty = lucy & righty= tighty & vica verasa. If you forget just remember...if you do not get thigs just right...engines are self healing. But be carefull..your fingers tend not to grow back. Just Lizzard tails do that ! Maybe that Geco Lizzard on the TV comercial could give you a hand? You know...the one called $tanley. Well hop to it mate...times-a wasting! [img][/img]
BCCHI
I was just messing around on here....last few days running a fever....bad sinus infection. Got some med for it.....just waiting till I feel better. If I work on something right now...it will mean more repair work. My head feels like there is a hydraulic jack...shoving the sides out..meanwhile...lucky to breath without chocking on drainage. I bet that blew your appitite! It did mine. Man I sure will be glade to feel better.....hurry up spring! Capt,n P.S. I think those Guys out West are more tough...Like Bill
